Guitar wiring - what wire to buy?
So ... I’m about to rewrite my new Jem.
I realized I’ve never had to buy wire, I’ve always reused or repurposed something.
I guess I just need single core shielded? I could use unshielded single core for anything thats just ground.
I also guess I only need shielded for signal->pickup selector, then to jack lead (?)
Any recommendations? What I’ve found so far looks massively over priced.
  • ICBMICBM Frets: 72808
    You only need shielded for the volume pot to the jack, at most - even there, a twisted pair is adequate.
    The best source of guitar wire I’ve found is to get an old Scart cable - common, free, and contains more wire than you’ll probably ever need.
  • FelineGuitarsFelineGuitars Frets: 11653
    Chris - are you still in New York?
    Do they still have Radio Shack or Fry's Electrical?
    To be fair 2 feet of cloth covered push back wire would be more than adequate
    Or  as ICBM said use a spare bit of Scart cable or the free HiFi cables that used to come with every item of Hi Fi just to get you started
  • Perfect!
    Thanks both. I’ll have a snoop down the local charity shop for a scarf cable ... (they have a box of crap cables).
    Failing that I’ll buy something as per Feline’s recommendation.
  • Tone Wire.
  • Tone Wire.
    I might just cut one of these down if I can't find a scart cable: https://www.thecableco.com/chordmusic-aes-ebu-digital-cable.html
  • @thermionic genuine LOL
  • prowlaprowla Frets: 4977
    I like the vintage-style cloth weave covered stuff, but it's a right pain to work with!
    (Goes off to check on old SCART cables...)
    What a load of pretentious pseudo-scientific waffle!
    "The lessons we’ve learned over the past few years have been both glorious and somewhat sobering. Glorious because the Tuned ARAY and the Super ARAY conductor designs can transform the sound from turntables, CD players and streaming devices into music that sounds real, believable and emotionally involving. Sobering because the Tuned ARAY and Super ARAY conductor designs explicitly show just how much more conventional cables designs can blunt the potential performance of pretty much any audio system."
    That said, I do have a £300 interconnect cable from my CD player to my amp...
    Just in case you missed it, the interconnect linked to above is a "digital" cable :D
