Otherwise, want!!
One of my originals was stripped to the wood, and you could see how the Bass V body was converted and why it ended up that shape - the 'scoop' on the end of the body was done to remove the drilling for the original bass bridge and its through-body string holes, and the hole for the ground wire is then visible on the edge of the body, plugged with filler. The neck pocket was reduced in size also using filler! Presumably by bolting a neck to it, filling the gap, then removing the neck before final sanding and finishing. Very crude.
It would be interesting to see if they've replicated the old Bass V pickup rout on the new ones...
https://eastwoodguitars.com/collections/guitars/products/eastwood-maverick-custom
These were actually nicknamed the 'Flying Can-Opener'...
Here's a screenshot, although you'll need to actually access it to get all the colour options and zoom ins.
