Some Gibsons, including double-cut Les Paul Specials like the one in your pic, also have fairly flexible necks and neck joints which doesn't help, and unfortunately there's nothing you can do about that.
It's unlikely to be the machineheads, even if they're old - even really worn ones will work fine if they're strung and tuned correctly (strings fitted tightly and preferably locked to the post, and tune only up to the note not down).
