If you're fitting active EMGs and you're buying new they come with the correct pots, but if you're fitting second hand ones they may not, in which case you need 25K Log pots and 0.1uF caps.
Be aware that the holes in the guitar will probably be 8mm and the new pots may be 3/8" (9.5mm) so you will need to ream them out slightly. The existing knobs may not fit the new pot shafts either, without risking cracking them.
