Chinese LPJ Kit
SlopeSoarerSlopeSoarer Frets: 851
edited November 2019 in Making & Modding
I ordered a LPJ kit from China via Aliexpress (Musoo) a few months ago and it arrived today. It took so long as what they sold wasn't quite how I wanted it, so they said send pictures of what you want, pay for it (£135 delivered) and they would make it for me.
I asked a couple of times where they were up to with it and they sent some very basic pictures. Overall I wasn't very hopeful and thought I'd get a box of firewood and end up putting it all down to experience.
Anyway so far so good and ideal for a first project before I spend more money on better quality woods and doing a bit more work myself. The body is one piece as is the neck. Body weighs 4lb 8.3oz, neck 1lb 3.6oz. 24.65mm at first fret and 26.55mm at the 12th.
For those that have done similar projects, is it worth while leaving the would to dry out/settle before starting putting it together?
Any advice on positioning the bridge?
As for finish my heart says do a Steve Robinson's TV Yellow and my head says oil.
1reaction image LOL 3reaction image Wow! 0reaction image Wisdom
  • sweepysweepy Frets: 4205
    That actually doesn’t look too bad at all, have fun :)
  • KeefyKeefy Frets: 2323
    Look out @IvisonGuitars then?
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    You’ll need to give it a bloody good sanding from top to bottom anyway but if you’re planning on oiling it the sanding is crucial. Just in case there is any glue residue anywhere that the oil won’t take to.
  • You’ll need to give it a bloody good sanding from top to bottom anyway but if you’re planning on oiling it the sanding is crucial. Just in case there is any glue residue anywhere that the oil won’t take to.
    It will need a good sanding as you say and I'll make sure I do it with the grain and look at what grits I should be using.
    There are two issues which I can see so far.
    1 There is a small repair in the neck pocket, suspect the router caught and took a chunk out. It has been very well repaired and is much more noticeable on the photos than in the flesh for some reason. There is a little residue of glue on the inside of the pocket. (looks like cyano to me).
    2 The control holes are not in the right place (surprise, surprise) probably 25mm or so further right than they would be on an LPJ. The body shape seems very accurate otherwise.
    The control hole placement is a little annoying but I will copy another scratchplate idea which should look good on it. Styled on a Gordon Smith which I think is only made for Forsyth's in Manchester. I did a rough template last night and it should work with a bit of playing around. Something like this.
    I'll kit it out with decent stuff and depending on how I get on with this I will swap it out on a better guitar in the long run. This kit will be about me having a go at finishing techniques.
  • SteveRobinsonSteveRobinson Frets: 7081
    That looks really good, amazing for the price.
    Be aware that TV Yellow is tricky to get right, but worth it I think.
  • SlopeSoarerSlopeSoarer Frets: 851
    I agree I think it is amazing for the price too, even with the issues.
    I did pay some import tax/vat (£21.37).
    The impression I get is that they would make any design you can think for not a lot of money but it won't happen overnight. I will probably give them another go with a bit more detail next time, just to make sure they got it completely right and I think they would.
    I've got some scratch plate material coming so I'll work on that before I completely decide on finishing (just to make sure I'm going to be happy with the look), it probably isn't the best time of year to paint in a cold garage anyway: )
    Cardboard Scratchplate Template Idea
  • Truss rod?
    Truss rod?
    Definitely one in there you can just about see it on one of the photos, I've not tried adjusting it yet, I've had notched straight edge and fret rocker on and neck seem fine, possibly a little chunky (C shape) but I can sand down, whereas I suppose I couldn't add to it: )
  • RolandRoland Frets: 8765
    It’s always worth letting wood acclimatise to a new location.
    There are a lot of online resources which describe bridge positioning. For alignment I like to run cotton or string from nut to bridge along the lines of the top and bottom E strings, that way I can see how close they come to the edges of the neck.
  • SargeSarge Frets: 2429
    Looks decent, but what the hell is up with that truss rod access?
    It came with this....
    10reaction image LOL 1reaction image Wow! 0reaction image Wisdom
    Looks good to me. Two way rod but you can fit a Gibson style bell truss rod cover.
  • FunkfingersFunkfingers Frets: 14581
    Bridge stud insert positioning advice will depend on exactly which bridge type you will be using. In all instances, the nut is your datum point for scale length measurements.
    Non-adjustable wraparound bridges need two offsets factoring in. One to approximate the intonation slant. The second to compensate for the path that the strings will take around the tailpiece.
    Non-adjustable wraparound bridges with the so-called "lightning bolt" preset intonation ridge require their stud inserts to be equidistant from the nut.
    The stud insert positioning for fully adjustable bridges will depend on the saddle travel range of the specific bridge design.
    I have not even mentioned the pitch angle at which some of the drilling needs to be performed. Perhaps, Steve Robinson is the best person to consult about these crucial details?
    I'm waiting for bits to arrive from various places, so in the mean time I thought I'd have a go at making a pickguard, I'm reasonably happy with it, probably a bit of fine tuning needed yet and I have another slightly different design to make before I make my mind up.
    I'm thinking chrome domed control knobs rather than the ones in the mock up.
    Here's all you need to know about bridge positioning:
    https://www.dropbox.com/s/gxzbb6524doqtn0/Double%20Cut%20LP%20Jr.pdf
    0reaction image LOL 3reaction image Wow! 3reaction image Wisdom
  • Here's all you need to know about bridge positioning:
    Thanks Steve that's great: )
  • TTonyTTony Frets: 27700
    Not just bridge positioning either!
    Thanks for posting that @SteveRobinson - very useful document.
     :+1:
    edited November 2019 tFB Trader
    Oh yes it's everything you need to know about making a DC (the best type) Junior!
    I should add that it's not my Dropbox. I just searched for a copy of the PDF and found that link.
    Or the alternative idea. Not sure which it will be (this one or the one a couple of posts up) but I suppose I'll know better when all the other stuff is done.
    Busy Googling finishing techniques. I'm also now thinking of alternative colours to TV yellow as for me it would feel wrong without the traditional pickguard.
