The strings will put a certain amount of force on the neck when tuned to pitch. This may or may not have an effect on the bow of the neck, depending on how stiff it is, but probably exerts a small forward pull. So you may or may not need to use the truss rod to get the relief you want.
Relief is increased by front bow, so if the truss rod is backed off (loose) you have your max relief already from the strings, only heavier strings would increase it. On a tele truss rod resists string pull on the neck and reduces bow or even adds backbow (reducing relief).
I don't think it affects string tension at all, if a string is tuned to pitch the tension is the same regardless of it's effect on the bow of the neck. So the string tension is fixed and the truss rod adjustment changes how much of that tension is shared between the rod and the neck itself.
Clearly the tension for the same gauge and make of string ‘must’ be the same, if they are tuned to the same note - but the subjective difference in feel suggests something is going on.
EDIT- I've just seen that springhead summed that up nicely while I was slowly composing an answer.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Reducing the truss rod tension allows the string tension to have a greater effect on the bow in the neck.
Correct adjustment is a balancing act between truss rod and your chosen string gauges.
On an electric guitar with a vibrato bridge, there is a further tension balance to be achieved between string tension and the vibrato springs.
NOTE: I have deliberately kept my comments general. For more precise suggestions, it helps to name the exact make and model of guitar under discussion in your opening post. Even knowing which end of the neck the truss rod adjuster appears at is relevant.
but not by a lot.. just a tiny amount..
if it lengthens enough to make you need to reset the intonation from the bridge saddles, then the string length and so the tension should go back to roughly what it was before..
so no... it shouldn't make any noticeable difference [provided the string gauge and tuning remain the same]..
