My music:- https://soundcloud.com/hubobulous
The only issue I had was with fuzz pedals that like to be directly connected to the guitar with no buffers in between.
The fuzz didn't sound right when its input is connected to the wireless receiver. I should add however, that this is likely to be an issue common with all wireless systems, not just the Smoothound one I was using.
OK, well this has enlightened me somewhat.
No-one's noticed any latency at all?
Put it another way, the real delay between the sound waves leaving your amp and hitting your ears can be way more than that on a big stage. Add the two together however and you can start to feel it a little, but no more than you would if you were a long way from your amps with a long lead.
Edit, I lied, mines a G30
No detectable latency so must be 3ms or less.
No signal degradation.
Way more than 30m range.
Andertons have an offer on at the moment..
https://www.andertons.co.uk/audio-technica-stompbox-digital-wireless-system-atw1501?lgw_code=16284-ATW1501&gclid=EAIaIQobChMIqI-EzZGc5gIVCbLtCh00IAxLEAQYAiABEgLwtPD_BwE
Blimey, that’s quite a deal. And it’s an ABY splitter
I might just go for that
Battery usage is the only downside - it can be a little heavy (2 gigs a pair of AA's) but I use rechargeable ones anyway so not an issue
The Line 6 G30 does, not sure about the others
