is coming from, so I use a stainless pot with little holes at the bottom which sits on a saucepan.
Nil Satis Nisi Optimum
Never understood the prejudices against microwaves for cooking vegetables as all experimental data supports it being good.
If you do want to try actual steaming, try using a decent sized saucepan and a stainless steel seive or colander to hold the veg, with a lid to reduce steam loss.
This keeps the veg separated from the water & you can just remove the seive when your veg is done & serve (or to cool it quickly under a tap if you are blanching).
Cheaper than buying a dedicated steamer, or a good way to see if you will actually need/use one.
https://www.amazon.co.uk/Tower-Essentials-Steamer-Polished-Stainless/dp/B01ICU1OZ4/ref=sr_1_6?adgrpid=53226087756&gclid=EAIaIQobChMIsrSI9_qj5gIVFuDtCh0K5wgSEAAYAiAAEgLeAvD_BwE&hvadid=259118621675&hvdev=c&hvlocphy=1007127&hvnetw=g&hvpos=1t2&hvqmt=e&hvrand=259817044896128465&hvtargid=kwd-315241709670&hydadcr=18513_1816622&keywords=steam+saucepan&qid=1575736251&sr=8-6
Good quality new potatoes are surprisingly excellent when microwaved, keeping a really nice texture, as well as all their flavour.
Otherwise a seive.
Don't have a microwave but they're fine.
usually only about £20 or so, last a couple of years then just get another
I cook almost everything in them, chicken turkey salmon from raw from frozen, rice, veggies whatever
if you like veggies super soft just top the water up and give a little longer, I couldn't live without my steamer, but I could easily live with that and no other cooking method
We have aluminum ones that sit on top of a saucepan, probably 40+ years old. One is ex military stamped
W /|\ D (War Department) .
Good for doing two Christmas puds on one ring.
Thought to myself; "that's not gonna get many subscriptions"
