Machines for a Levinson Blade
Can anybody help me on this? I need a set of machines for a Levinson Blade neck it's a Japanese Texas model.
I've finished a couple of projects, so I'd like to get the guitar I've built around this finished...
I'd like to do it without drilling new holes.
(It's now got the springy string tee.)
Thanks!
  • ICBMICBM Frets: 72486
    Schaller M6 Minis and Gotoh SG360s should fit that screw hole position - I think the originals are Gotoh.
  • prowlaprowla Frets: 4931
    edited December 2019
    Thanks - the pesky screw hole position seems to vary a lot!
    I've got some Schallers, but their screw tab is down at a right-angle rather than along. The minis look right, though.
  • SteveRobinsonSteveRobinson Frets: 7045
    You need to find tuners with a "135" fitting, i.e. the screw hole is 135° from vertical.
    Those @ICBM suggested are ideal.
  • GluedtoMusicGluedtoMusic Frets: 74
    Those mini tuners come in two different sizes, can you measure the distance from the centre of the tuner post hole to the centre of the screw hole? Modern Schaller minis are 9mm centre to centre, where as Gotoh SG360s are 10mm, it might not sound like much but it can make the difference between a set fitting or not.
    Supplier of Gotoh, Fender, Gibson, Faber, Schaller, Hipshot, Floyd Rose, TonePros, Graph Tech, Hosco luthier tools and many more.
    1 set of Gotoh SG360s fitted - straight in, screws went in smoothly.
    Thanks for the help!
    Great stuff!
