I've sanded one of my guitar necks down to the bare wood and really like the feel of it.
Would it be safe to leave it like this, or will I need to put something on it?
Thanks.
This may or may not be the recommended way, but I'm a complete amateur and it turned out OK
I have the squier bronco bass, and I like the feeling the neck has, as if it's unfinished.
As you say, you can still slurry and buff Danish Oil but it is a bit harder wearing than Try-oil for a neck. I love the tru-oil slurry and buff finish but after some hard playing over time I always find I have to re-buff it. No big problem, but I find Danish Oil just that bit more resilient.
For a body, though, I would usually go the Tru-oil route...
Is it totally necessary to buff the neck with fine grade wire wool afterwards? That's what I've read.
I think it depends on how thick the oil coats are. If you rub in properly, there shouldnt be a need for wire wool. I have an oiled neck and do give a clean, scuff and recoat every year or so, but literally just a couple of Truoil coats rubbed right in and left to dry. Rub down with a clean rag to and start playing again @proggy
Thanks for the tip @charlola
@Roland - I have used PolyX for a variety of wood finishing roles, but have never tinted it. What would you recommend for the colourant? Any spirit based stain, or do you need something specific?
Cheers,
Adam
Ah, OK. Thanks for the reply - I suspect that, like all finish queries, testing, testing, and more testing is the way to go then. I have a couple of spirit based stains so will try those.
Cheers,
Adam
