It would be good to be able to separate tuner/tap tempo out but the problem is that by using an external switch for tap tempo you won't have the flashing led ring which is essential imo.
The only thing you wouldn’t be able to do is alter parameters on each block, such as gain/volume/delay time etc, which you can do in snapshots on the Stomp.
As mentioned above though, assigning tap tempo to an external switch means you don’t have the blinking tempo indicator. So, you would need to decide if you wanted to use your Stomp in snapshot mode or use the tap tempo
