Slide, open G
Can anyone talk me through the basics? Any online lesson recommendations? Fingers or pick? String muting? Got the guitar set up, just fine tuning it all.
  • soma1975soma1975 Frets: 6720
    Fine tuning will help.
    Andy Aledort does a great slide course on truefire
  • GulliverGulliver Frets: 850
    These are my generic tips for anyone learning slide - regardless of what tuning you're using.
    1 - ignore advice on which finger to put your slide on - use which ever is comfortable.  I used to try and force myself to play with a slide on my little finger, but I switched to my ring finger and it improved my playing overnight.  Do whatever feels right to you.
    2 - get your vibrato right - there's nothing nicer than good slide vibrato, and will help if your tuning is slightly off.
    3 - adapt what you already know - try and play some of your stock licks with a slide, then try a combination of slide and fingers. Then try in different positions and different combinations of slide and fingers.  You're already halfway there knowing what it should sound like!
    Hope that helps!
  • DulcetJonesDulcetJones Frets: 515
    edited December 2019
    I have one more to add to Gulliver's post:  Always have whatever fingers available on the nut side of the slide muting the strings between the slide and the nut.
  • FunkfingersFunkfingers Frets: 14474
    In Open G Tuning, do not attempt Duane Allman or Elmore James licks. :)
    Bottleneck guitar is similar to fretless bass guitar in that you need to judge pitch aurally rather than visually by fret position markers. Practicing in near darkness forces the issue.
