Hi all
I recently upgraded my M-Audio 2x2 interface to a Komplete Audio 6, which looked like a suitable interface for me, and decent VFM with it's SPDIF connections.
It is setup as
Guitar -----> Kemper -----> Kemper SPDIF out------> KA6 SPDIF in ------> Monitor speakers
The interface is also attached to my Mac via USB.
I can use the interface as monitors for normal audio playback from my Mac - Spotify, YouTube etc.
I can also record and hear my guitar signal using Logic.
My biggest problem now is monitoring the guitar signal without launching a DAW for general practice, something I have been doing for years using the M-Audio interface.This is because the interface only supports "direct monitoring" for the inputs 1 & 2 ... not for 3 to 6 (with S/PDIF being inputs 5&6).
Inputs 1 & 2 are both on the front of the interface and I like to keep untidy cabling to a minimum as my desk is a little cramped already, so was hoping that using the inputs on the rear would be possible.
Any suggestions for a sensibly priced interface that can utilise direct monitoring via SPDIF or another rear mounted input?
Or is there a software alternative to what I'm trying to do - a mini DAW type thing?
Or do I go back to the M-Audio which to be honest does work for me, I wanted to try SPDIF to get a stereo signal out of the Kemper?
Many thanks,
Simon
https://twitter.com/spark240
Reddit r/newmusicreview
I'll probably put up with the fact that I have to launch Logic for monitoring purposes - not too much of a big deal, would be ready before the Kemper had booted up anyway!
Not convinced in the interface long term though, will be looking out for a suitable replacement soon enough.
Cheers,
Simon
But there should be some kind of control panel software for your interface that lets you set the inputs to be monitored. It often looks like a mixer but not necessarily.
I'll see if I can find out on Google.
I think I might have been mistaken about the switch, I'd definitely put that to 3-4 and have the input-host knob in the middle (with the Kemper connected to inputs 3 and 4).
If that still doesn't work then it's seems you're right about direct monitoring only being available on the first 2 inputs. That would be really shitty of NI to omit direct monitoring of analogue inputs. Surprisingly bad.
If that turns out to be the case and you'd rather spend money than use the front inputs I can tell you that on Focusrite interfaces you can definitely directly monitor all inputs including spdif. So whichever Focusrite model has the right number of inputs on the back for your needs would be a good bet.
Thanks for the info, you’re right about NI being shitty - completely took me by surprise, but it appears that the current version of the interface is hard wired to only allow direct monitoring using analogue input 1.
i can work around it for now by always having Logic running with a track open for monitoring, but I can feel me changing it soon enough!
cheers,
Simon
https://support.native-instruments.com/hc/en-us/community/posts/360006216618-Manual-for-Komplete-Audio-6-mk2-not-available-en-us-
I'm wondering if the Zoom U44 offers direct monitoring of SPDIF signals as it can be used as an audio interface and as a standalone AD/DA converter. I would suggest looking further at this interface.
