I intend to strip it all the way back and use a oil/stain for a more natural look
If it's DIY spray can job it's most likely solvent-based, will wipe off with celly thinners or acetone. Messy old job but gets there. Easy to test as well, if it marks up with a kitchen towel it's a solvent based 1k paint.
If it was paintshop-sprayed then it could be two-pack (aka 2k) which is much tougher, but a strong trade or bodyshop stripper takes it off eventually, with wrapping and several goes, it's not instant. DIY shop paint stripper won't work. Heat may work but have to be a bit careful. Sometimes it works very easily, sometimes not.
Also if shop-sprayed it could be both types - solvent-based basecoat colour, with the tough 2k clearcoat over it.. the primer could be all sorts.
Has a Dimarzio Evo2 Bridge, unknown seymour duncan mid(really old looking) and apparntly a schaller in the neck
