Hi guys,
Looking for some recommendations for a portable PA system, for using at smaller venues/weddings etc. 99% of the time it will be 1 mic and 1 guitar.
I won't be using it an awful lot, so don't really want to fork out for one of the Bose systems, but definitely want the same design so that it's easy to transport and takes up very little space
Cheers in advance
Keir
Ive seen a couple of Sub-Zero ones, but haven’t heard of this manufacturer before?
The same applies - it's fairly down-to-budget gear, but not as poor as you might think from the relative pricing because they're supplied direct from the factory, and I suspect they have a avoided a lot of R&D cost by simply copying another maker's product... but given that they're less than half the price, I still wouldn't expect the quality to be the same.
Don’t really have £800 to be spending on something that will get used a couple of times a year, so might just take the punt on one of the lower priced ones
400 RMS per tower, clear, great sound dispersion, you could add another for a stereo setup at a later date.
We use our pair for pub gigs, putting 2x vocal mics and 2x acoustic amp DI's into them (acoustic 6, 12 string and occasional mandolin) and a bit of kick drum from my compact kit. We've not had the need to turned them up past halfway yet and have had plenty folk up and dancing
If it's just guitar and vocal I doubt your find a sub useful, being as neither got much below 120Hz or so
All if the other systems look great, but they’re either more than I want to be spending, or are about as big/heavy as the speakers/system I already have tbh. I’m just after portability and easiness for set up/take down
