I've been using my iloud micro monitors for mixing and media consumption for about 1.5 years and I've finally outgrown them as I've been finding them lacking as of late.
I think they're great for the size but ultimately, they lack depth (low end) and richness (they sound small?). It is tedious to have to keep switching to headphones to check bass etc while mixing.
My music space is not ideal as it is close to the wall, but I'll tackle one problem at a time..
I can probably set aside enough to get a pair of Yamaha HS7s or HS8s, which would be the upper limit of my budget. The Kali LP6 looks interesting but I'm afraid that there won't be enough low end considering their size. In this price range, it is quite saturated with a whole host of options including Adam, KRK, JBL. Any suggestions?
Edit: I shouldn't assume that everyone knows how much yammies cost. Budget is £500, so I won't be getting kii threes...
A £300 sub will give you all the bottom end you need, right up to the point that the room starts interfering and you need to spend a load of money on bass trapping.
I'd argue that in an acoustically compromised room you actually want smaller drivers- certainly not anything over 6.5" or so.
Going for something wth larger drivers in an essentially untreated room will just highlight deficiencies in the room and give you loads of problems.
You can't solve this problem by buying bigger speakers unless you are prepared to treat the room.
There are a few detailed reviews of the two side by side and there's not much difference between them quality wise.
Taking on octatonic's advice, they're both 6.5 inchers, so that's one aspect sorted.
Unfortunately, this is a temporary rented room, so I am not in a position to treat it.
@winny_pooh thanks but as I'm not in the UK, I won't be able to purchase on ebay UK.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Based on what's been said, and the great reviews, I'd likely go and try out some Kalis! I have seen you mention them specifically before, which put me onto them in the first place.
Yes, acoustic treatment is the boring and necessary purchase.
https://twitter.com/spark240
Reddit r/newmusicreview
Ilouds are okay but most proper monitors with bigger drivers will sound better, irrespective of acoustic treatment.
To be honest the ilouds are okay but I regret swapping 5" monitors for them.
I was relying on an Audio Pro Addon C5 + Sub for play back before, or headphones.
This is a big upgrade
Now I have the quandary of what do with the Audio Pro gear as it's great for streaming and as a Bluetooth speaker when I'm practicing or just relaxing. Do I need 2 systems in a small from though...!?
Either way, I'll test them out in a store before buying..
I have 6 inch monitors but if I was buying again for this room I'd go smaller.
The unfortunate reality is that in this room the bass is just shockingly bad and will be for any speakers so I'd rather have less of it bouncing around.
The room acoustics thing is the huge problem for home studios. We now have as good, or better, technology that any of the top studios ever had but the room problem is big and very difficult to solve.
I even looked in to the very expensive and inconvenient idea of having a lot of bass traps around the room but when I researched deeply in to it I found that even putting a lot of money in to it and having a ridiculous amount of fiberglass in the room, it still only improves things a bit - it doesn't give the flat response a real studio has.
The only way I got over it was when I stopped caring about subtle quality as much as I used to. Now I only mix for musicality (fairly roughly) and then check it on various systems and environments adjusting if necessary. Years of doing that kind of teaches what things that cause problems elsewhere might sound like in my room or on headphones. But basically if the parts can all be heard as they should and the parts are in the correct order of loudness, I don't bother going any more precise.
If I ever have a potential hit album I can always have it mixed by a professional.
That Yamaha sounded great but not much difference from the Kalis, just a different signature. Both would be usable. The JBL didn't go as low as the other two and lacked a little subbass.
Both the JBL and Kalis have a slighttttt hiss if u really go close to it. I think the JBL is a little quieter than the kali. Yamaha was best in this department.
The salesperson was really helpful and mentioned that the Adam a7x is similar in pricing to Yamaha and really good. Unfortunately, it was closing time by then so I didn't get to pester them to set some up.
Still deciding but have a better idea now.
I thought I might need more bottom end, and went though auditioning HS7s, Adam A7xs and a couple more - but bass in my smallish room.... I ended up adding a Yam HS8 sub to the A5xs instead. Lower Freq range then the 7" cones, more controllable, and I can turn them on and off to mix (mix check etc) as well as headphones.
Recently changed the A5xs for Neumann's - KH120s so again 5" Driver.
What size is the room you use?
I ended up getting the Kali LP6s after auditioning JBLs, Yamaha and kalis. The store had Adams as well but they were behind my budget. So far so good!
The kalis have adjustment options so they can compensate by reducing bass when put near or up against a wall. Good feature! I definitely can hear the difference. By default it was boomy and uncontrolled, after adjustments, the bass is much more balanced.
I can tell a sub would be helpful for ultra lows. Something for the future!
I have a 6m x 4m mix room and my seat is 2.2m from one wall.
But then again, I am guessing that your seat is facing the 4m wall (and not the 6m wall), whereas I'm facing the long side of the room.
