Ended up getting a TDK1 DMK, which is their entry level full mesh kit, then upgrading the brain to an older TD9, before adding a VH11 proper hi-hat and a bigger snare pad.
Just because you're paranoid, don't mean they're not after youDid you play the Crimson kit to compare to the Roland? I have played the more expensive Roland kits quite a bit but I haven't had a chance to try the TD-1DMK yet.
I played the Alesis kits within the same price bracket and found the pads less responsive to variable velocity strikes and really didn't like the stock sounds.
As always though, personal preference is key.
I changed the hihat for the feel and playability of an actual moving hi-hat, rather than for soubd reasons. The samples are pretty similar I just get better response.
Just because you're paranoid, don't mean they're not after youEbay mark7777_1
