Hi All,
I have recently moved to a bigger home which includes a fairly sizeable detached garage. As I don't own a vehicle to put in it, and never will, My intent is to turn this into a studio/gym hybrid.
I'm in a fairly loud area, so I am not anticipating complaints from neighbours, but I would like to sound proof a bit, to prevent outside noise from getting in, as we're near to a school and those little buggers are noisy. I would also like to make the room, or part of it at least, sound better for recording purposes. I'm not anticipating doing anything truly professional, but I have often heard it said that the best way to improve is to record oneself. 3 walls of the garage are pure brick, with a metal front wall which raises to allow a car entry. I want to block this off so only the side door permits access.
Any suggestions on ways to soundproof which won't kill my bank balance completely? Keep in mind that I am not really capable of much DIY sadly.
Thanks
Feedback
The easiest and most effective way to treat a common garage is
Walls ...... battern the walls at 600mm intervals, fill the voids with acoustic grade heavy rockwool slab. Then vapour barrier then 12mm plasterboard ... all joints taped and filled then put another layer on that ... hang one layer vertical, the horizontal so the joints don't all land in the same place.
Ceiling .... sound goes through the roof so I tend to hang a false roof under the real one on 6 x 2" posts after the walls are done. Hange the joists on the posts then wire up rockwook then cover with 18mm MDF and a couple of layers of 12mm plasterboard.
Main doors .... build a concrete block wall inside where the main door is .... concrete blocks not breeze or Thermalite ... you need the mass of concrete .... render afterwards then battern - Rockwool - plasterboard
Entrance door ..... build another inside around 400mm so there's an air gap between the 2 doors. Use a solid door
Windows ..... once the walls are done the window reveal will be 74mm bigger than it was so by a doubled glazed unit the right size and fit that in the hole ..... buy the thickest glass and biggest cavity they offer.
Electrics ... don't be tempted to sink pattresses in the plasterboard for neatness ... this will compromise the soundproofing. Surface mount sockets with surface sockets and small stick on trunking
Remember the lower the frequency the harder it is to stop. The above treatment will certainly enable you to blast guitar at deafening volume but bass guitar and kick drum will go through literally anything short of a floating room within a room. You will find though that once the low frequencies have escaped the garage they will lose all energy a few metres outside it
I have done 2 full on garage conversions using the above, a very large recording booth and a professional control room in a studio. The DIY skills involved are pretty basic, just basically cutting timber and plasterboard and screwing in screws.
The biggest mistake people tend to make is they don't think the build through .... you need to work out on paper where things go based on their actual size .... plasterboard is 2400 x 1200 or 1800 X 900 ... rockwool slab is 600mm for example
I had a blast in my garage studio when it was done and recorded many bands demos plus my own album and various other bits and pieces. Tracking drums was never done late at night but guitars certainly were. I remember one night setting up another take and walking outside for a fag and the sound just disappeared ... I could hear the motorway in the distance despite the fact my mate was playing through a Fender Twin at half whack not 3 metres away. Very satisfying
