I've got a stock 22, not the +, that I've owned from new. Love it apart from the volume jump in Lead mode that was addressed in the + version with the additional Lead Master control on the front panel.
Anyone here done that mod? Is it also worth doing the Lead Drive mod, sanctioned by Mesa, which varies the level out of V1 which is added in Lead mode?
I'm going to use the Direct Out pot on the back panel for the Lead Master, no drilling and it's the right value. I could replace the Direct Out socket with a Lead Drive pot.
There are a few other tweaks in the audio path for the + version. Anyone done those as well? I can see what they do, just don't know if it's worth it.
Anything else worth doing when I get it in bits? I swapped out the PSU filter caps a few years ago when they started to fail so they should still be fine. I was thinking maybe go all metal film around V1 as it's quite hissy in Lead mode. May or may not help.
