New tuners recommendation
Could you help me decide, or recommend, some new tuners for my Hondo lead copies?
Both guitars have the original tuners on, and work ok-ish, but a recent change to 10’s on one is causing it slip a little. Not to mention the bushings fall out when I change the strings ( most are wedged in by bits of paper!)
I like the look of the these locking ones from
axesrus at £37
https://www.axesrus.co.uk/Axesrus-Aluminium-Lockers-6-in-line-p/lc1844an.htm
Only problem is i’ll have to enlarge the holes to 10mm
Or some Kluson a likes at £24
https://www.axesrus.co.uk/Axesrus-Deluxe-Machine-Heads-p/aruvintmh.htm
Which I like and have the added bonus of not having to re drill the headstock.
It’s this guitar
    Don't have experience of those tuners but what I will say is that enlarging the holes is so easy and quick to do using a reamer that costs pennies if you don't already have one so don't let that put you off.
  • DiscoStuDiscoStu Frets: 5523
    The Axesrus locking ones are decent, or at least the ones I bought in the past were. Just buy a reamer and get to work on them holes.
    Or you could look at Gotoh, their stuff is usually bang on.
  • ICBMICBM Frets: 72448
    If you’re going to enlarge the holes, get one of these -
    https://www.stewmac.com/Luthier_Tools/Types_of_Tools/Reamers/Rear_Peghole_Reamer.html
    It makes a perfect job and is foolproof to use.
    Even if you use a normal reamer or drill, always go from the back of the headstock, and only deep enough to take the tuner body - *not* from the front or all the way through. The threaded collar will go through the original hole.
