Hello
I'm going to be off to Coda in the next few weeks to try a loads of acoustics. My mind was on an OM or 000 but after diving into this world more of research I have discovered that 12 fret guitars could be a good shout.
I'm 5 ft 9 and have recently discovered i'm suffering with RSI in both arms. It has been mentioned to me that a shorter scale length guitar would be better and I should try 12 fret. There are more choices out there and i'm looking forward to try a few.
But i will need a cutaway.
Lowden are now doing S, F and O shape in 12 fret, Taylor do a big range too.
But having a more comfortable experience playing should in theory help with this?
Any one experience with 12 fret guitars?
I love 12 fret guitars and I've definitely found them more comfortable than 14 frets. To be honest I prefer the sound too, the bridge position in the sweet spot of the lower bout and the neck join at the octave really does make a difference. My signature Kostal guitar is a 12-fret cutaway, there's more info here.
Check out my YouTube channel for videos of luthier-built and vintage guitars!
Luthier Stories - My series of interviews with some of the world's greatest guitar makers
Im really interested to hear and feel the differences. Coda have stock of lowden and taylor and I can A/B them against the 14th models.
any other brands in reasonable budget? I guess Custom order can be made with any brand but off the shelf?
https://youtu.be/1dqQJpwBSSc
For RSI issues a shorter scale length could help but I would also recommend ensuring the guitar is properly set-up, use of lighter strings (e.g. Newtone Heritage) and good technique and posture when playing. A guitar support (e.g. Dynarette or Neck-Up) can help with the latter.
I've got a custom Avalon 12-fretter with a cutaway. Lovely guitar but I wouldn't say it is any easier to play than a 14-fretter of similar dimensions.
https://www.youtube.com/watch?v=y1Db6EpgXBc
All the best
Michael
is it your hands, wrist, shoulder, elbow or arms that are a problem?
12 fret and a small body would reduce the stretch on your arm, and the amount your playing arm has to bend out to clear the body
is it your fretting hand?
Is the RSI from playing guitar, or work?
Have you seen a physio?
If not I would, in some towns you can self-refer to an NHS one
Depending on your budget, I'd recommend finding a highly-recommended private one
Mine does 50/50 NHS and private, but is a genius for how muscles, joints, nevers, ligaments, etc work.
Typically £40-50 for an appointment, then at least you know what's wrong in more detail
I thought I had carpal tunnel years ago based on common sense and GP diagnosis. Now I would (and do) go to the physio first, they are specialists.
It could be a combination of things, I am no expert other than an expert in deciding who can best help me.
If your plucking forearm is a problem, it could be triggered by the edge of the lower bout, is it worse in a T shirt and OK with a thick jumper? If so, one of those forearm rests would help a lot. Also you can get a little sleeve to wear to stop the edge of the guitar bothering you as much when playing in a T shirt.
The angle of the plucking shoulder can be a problem too, position and body size are key to this.
As recommended, a dynarette cushion can help, I use one for all acoustics, and vary my leg position based on the guitar body size.
Have you done a lot of weight training? Just as an example you can get shoulder damage that requires sub acromial decompression, which cause upper arm symptoms. I got it without weight training, I know others who got it from heavy lifting at the gym or manual work above head height. I had muscle wasting a way in my upper arm, and was in pain all the time, sadly the first physio thought it was just laziness. The next doctors thought it was nerve compression, but then they realised it was plain old shoulder damage (it's one of the most common operations performed btw), yet few seem to have heard of it.
i was very concerned as my arms where just locking up and was very painful so I couldn’t play.
i saw a chiropractor who eased the pain but could diagnose why. At the time I was doing a lot of body weight exercises which was heavy going on wrist and shoulder. I was also playing and holding the guitar for long periods and shoulder pain was evident.
i do get neck pain and it I get a stiff neck so it’s all triggered fromtgere down to you arms.
i have since then work with a physiotherapist, stopper body weight training and really looked at posture.
im in a much better way but I feel the guitar could make things even easier by short scale and 12 fret with cutaway,
I’m looking forward to trying the lowden S 12 fret with cutaway. Ticks all the boxes?
Have you taken a guitar to show the physio how you hold it?
the maton depth is wider than a Dreadnought so it’s hard to get it in a perfect position.
I haven’t done that yet. But good shout!
When using the neck-up (or Dynarette - I've got both) it is important to pay attention to your posture. It will help if you sit on a hard seat with both feet flat on the floor.
Hope this helps - and does not put you off your pursuit for a new guitar;)
Feedback
Regarding the Alexander Technique - it is certainly not a pseudo-science or new-age mumbo jumbo. It is widely used and proven by musicians to both overcome issues such as RSI and also to improve performance.
I'll leave it there - but, as I mentioned earlier, I'd never want to put someone off buying a new guitar;)
They're the ones that end in '2' so 312c through to 912c
