GIBSON USA J15 - ELECTRO ACOUSTIC GUITAR - 2016. Condition is Excellent.
The J-15 is handcrafted from solid tonewoods, Sitka spruce top, walnut back and sides, and a maple neck. Built by master-craftsmen using the same methods as all Gibson Acoustic models, the J-15 has a hand-fitted dovetail neck-to-body joint secured with hide glue. This particular guitar has a stunning Walnut back and sides with lovely figuring and grain. The Sitka top has lovely silking.
The action is spot on for ease of play and the neck is straight and true.
Factory fitted L R Baggs Element pickup system with hidden soundhole volume control.
Specifications:
Top
Wood Species: Sitka Spruce
Pieces: 2
Grade: AA
Binding: 4 ply top
Back
Wood Species: Walnut
Pieces: 2
Binding: 1 ply
Weight
Average Weight (body only): 1.16 kg / 2.57 lbs
Neck
Wood Species: Maple
Pieces: 2
Details
Truss Rod: Single Action
Profile: Slim Taper
Thickness at Fret 1: 2.10cm / .827"
Other Materials: Franklin Titebond 50, hot hide glue neck joint
Average Weight: 444.5 gr / 15.68 oz
Peg Head
Type: AJ
Logo: Block Decal
Headstock Angle: 17 degrees
Tonal, Resonant, and/or Technical Effect: Compound Dovetail neck joint for resonance distribution throughout guitar
Neck Fit
Joint Angle: 3 degrees
Type: Compound Dovetail
Adhesive: Hot hide glue
Gauges Used:
Short Scale Pitch Guage, Rule
Nut
Style: Traditional
Material: Tusq
Width: 4.38 cm / 1.725"
Slots:
E: 0.053
A: 0.042
0.032
G: 0.024
B: 0.016
e: 0.012
Fingerboard
Pieces: 1
Fingerboard Details
Radius: 30.48 cm / 12"
Frets: 20
Nut/End of Board: 4.38cm / 1.725" @ nut, 5.689cm / 2.24" @ end of board
Scale: 62.865cm / 24.75"
Side Dots (Color): White
Fingerboard Inlays
Style: Dots
Material: Mother of Pearl
Average Weight: 99.79gr / 3.52 oz
Tuning Keys
Style: Grover Mini Rotomatics
Weight: 33.56 gr / 1.184 oz
Tuning Keys Details
Tuning Ratio: 14:01
Plating specs: Chrome
Part numbers: 140-130-610
String Dimensions
E: 0.053
A: 0.042
0.032
G: 0.024
B: 0.016
e: 0.012
Bridge
Style: Rectangle
Material: Walnut with Tusq saddle
Part number: 140-120-911.5, 140-130-866
Weight: 13.60 gr / 0.48 oz
Output Jack
Style: 1/4" mono
Pickup
Style: L.R. Baggs Element
Plastics
Pick Guard Style: Tortoise Teardrop
Part Number: 140-130-957
Truss Rod Cover Style: 2016
Part Number: 140-130-840
Accessories
Case Style: Hard Shell
Color: Black
