So my live keys rig is betting bigger. Currently Im daisy chaining my midi cables. so RD to FA (I do play FA sounds from the RDs zones) then to my peak, then to my Legend EXP module - and with the incoming Argon 8M to that as well.
Ive not had any obvious issues to date, and Im only transmitting note data (ie what I playing) - hold info (from a latch pedal) and volume (from an expression pedal).
Am I OK to keep doing this, or am I better adding a Midi slitter after the FA - then separate runs to the modules?
If so - is a passive box OK, or do I need a powered box? - Id rather not run more power cables if I can help it. Im already at 7.....
I've one on order from the initial campaign but isn't likely to arrive until March/April and then it'll probably take me months to get around to using it...
I have one patch oer song, and there saved in set order. Finish song, patch up on each unit.
