How much to fit a K&K Pure Mini?
TimmyOTimmyO Frets: 7524
I think my tiny local shop is a dealer - if I go an in put my money on the counter what’s a reasonable sum to be charged for fitting it? (To a D28)
thanks
PS I am super impressed you did yours yourself, but I don’t want to do that :-)
Red ones are better.
  • mgawmgaw Frets: 5282
    I was charged around £40 a while ago by Mansons
  • ICBMICBM Frets: 72510
    edited March 2020
    Whatever the standard charge for one hour's labour is - I would charge £40 as well, but anything around £50 is reasonable if you have shop overheads etc involved.
    It's not really an hour's work in terms of actual hands-on time, but takes a bit more than an hour due to having to wait for the glue to set three times. AKA tea/Fretboard time .
    And you are right - it's not a technically difficult job, but it's much easier if you're experienced at working through the soundhole and handling things covered in superglue where you can't see them... and also reaming a half-inch hole in the end of a two grand guitar ;).
  • TimmyOTimmyO Frets: 7524
    Cool - thanks chaps.
  • I’ve paid £50 footing for all the pickups I’ve had fitted by my local trusted luthier.
    fishman undersaddle - 00-15
    baggs lyric - D18-GE
    so an hour’s time seems right to me.
    Cheers
  • FunkfingersFunkfingers Frets: 14520
    Thank Clapton for brown overalls.
    Furch/Stonebridge use an expandable metal end pin device. Simple screwdriver job to remove and to refit, should that ever become necessary.
    And the rest
    https://www.peachguitars.com/guitars/acoustic-guitars/cf-martin-d-28-authentic-1941.htm?opt=15048&gclid=EAIaIQobChMIv8igvqCL6AIVyNDeCh3E3wI3EAkYASABEgJLrvD_BwE
    TimmyO said:
    And the rest
    If it's an Authentic 1941 then a big split in the end of the guitar is just historically accurate and you don't need to worry about it.
    Did the real ones not fare well then? I know almost nothing about old acoustics - this thing just blew me away, vintage-authentic or not
    Mostly they're fine, it's just a few that have splits - usually caused by them being dropped on the end pin, which is tapered and so has a tendency to split the block if it's really hammered into the hole.
  • FelineGuitarsFelineGuitars Frets: 11619
    We fit a lot of them , and also the JJB brand ones .
    Typically about £40-45
  • LewyLewy Frets: 4238
    In your expert opinion, is the K&K superior or are the JJB ones just as good (as fans of them claim)?
  • TeyeplayerTeyeplayer Frets: 3230
    Exactly what I was thinking.
