Does no one fancy playing them?
- neck is too narrow and some players find it difficult to play chords
- intonation is off as it doesn't have 12 individual saddles
Or you find that the strings need changing, and after staring hard at it for a couple of days and realising that they don't change themselves, put in the case to be done later... and after a year or two, proceed to Step 3 above.
Also, Rickenbacker finishes are actually quite durable, much more so than nitro - older ones were polyurethane 'conversion varnish', now they've switched to UV-cured polyester, I think. The CV ones can actually suffer from reaction to stands though, so don't assume they're indestructible.
Mine are certainly not pristine, but they're 47 and 52 years old, and have clearly had quite a hard life. They're in much better condition than a similar nitro-finished guitar with the same history of use though.
No intonation issues to report so far.
