https://www.boobooguitars.co.uk/collections/guitar-bodies/products/tc-body-512282
And if anyone buys it in the next 24 hours I'll be cross.
Conversely you can get something like this for £81.... https://www.guitarbuild.co.uk/collections/guitar-bodies/products/tc-body-827621
If you're handy with tools, you could rout out the know, nick a bit of wood from under the scratchplate and graft it onto the body. But that's a lot of work to save £15.
https://www.ebay.co.uk/itm/254542839925
I'm going to break this baby up. I had a voucher plus I don't need to needlessly buy a bunch of black hardware... Cos it's already got it black hardware. £99 plus postage.
I'm not quite there. This Partscaster journey has gone weird.
Apparently, both guitars are immaculate but we all know what that means,
T type necks usually have a squared off end with rounded corners. S type necks usually end in a gentle arc. Hence, an S neck can fit into a T pocket (leaving an air gap) but an S pocket will not accommodate a T neck.
Even assuming that your two necks are interchangeable, the only difference that the swap will produce is cosmetic. i.e. You will make a Squier HH Telecaster resemble a Chapman ML3.
New electrics, saddles, tuners, pickups, nut etc
