Years ago I bought a used US Telecaster that had led a bit of a hard life. Still, at a time when I wasn't playing very much it kept me going.
Long story short, I've previously attempted to renovate this but it wasn't a great job, certainly not to the standard I wanted. So the parts languished in my attic for a good while. I find myself with some time, more skills, and (I think) all the things I need to get this back together.
May as well pop a thread up here in case people are interested, and also it'll keep me motivated to get it done.
Progress so far:
This is where we started. A box of dusty slightly shabby bits.
The frets had some fairly significant wear, so I decided to get a basic fret toolset and have a go at sorting them out. If I did that first and screwed it up, at least I hadn't wasted any more time and money. I watched some tutorials and had a go. From other hobbies I own a Dremel and a three-stage clay polishing kit used on steel. Once I'd got the frets level and reshaped I finished with the polisher.
It went better than I expected, which was a promising start.
I've sanded down the body and neck and I'm making progress on them. Will post some pictures when they're ready.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
So I stripped all the old finish off, worked through the different paper grits and redyed the body with what I had left of a bottle of Crimson Guitar's black stain. It's pretty opaque after a couple of coats, and in my experience it's a case of rapidly diminishing returns if you apply more. I wanted some of the grain to still show.
Since my last rebuild attempt I actually bought a Baja Tele from the forum, which I really like. Because the body is routed quite flexibly, I've decided to drop a humbucker in the neck - mainly because I've not owned a Tele with that pickup configuration, so why not try with this?
It's going to get finished with Osmo Top Oil which I have left over from a kitchen worktop install. I'm kind of going with what I have, and I know people on here have used PolyX with a lot of success. As I understand it the formulation is similar.
Now, there's a bit of a mystery about the neck. When I put the serial number (removed by me in a prior attempt to refinish this thing) into the Fender site it came back as a Strat, but it's definitely a Tele neck. Given the guitar and all the bumpf that came with it I strongly suspect it might be an error rather than suspect. Regardless, it's a nice neck!
Anyhow, the neck is now very smooth and satiny. First coat of oil was rubbed in using 1200 wet & dry, and then it was cloth application after that. There are a few micro scratches if you hold it up to the light in a very shallow angle, but you can't feel them. For the purposes of this project, that's good enough.
Base of the neck and what I assume is a part code. Dated Jan 2005 on the butt of the neck.
The grain isn't quite as pronounced in actuality as the photos, but it gives an idea of how it shows through the stain. The wax tends to lift a bit of the dye out for the first coat or two.
Now I just have to wait a month to sand and polish...
Depending how well you prepped and how much lacquer you have on you may not have to wait so long before flatting back.
I'm a bit paranoid about sanding through after the work I've put in, so I'm happy to err on the side of caution when it comes to cure times.
Any advice appreciated!
It's very easy to sand through so just be careful, especially at the corners.
The finish turned out way, way, better than I was expecting. I'm very happy with the result - so thanks to everyone on the forum who posts tips and guides.
Top work!
