How is the speaker power rating spread across such a network?
Cheers,
Adam
So, if the amp was putting out 50W max, then each 'arm' of the parallel wiring would receive 25W? Therefore the 8Ohm speaker would need to be at least 25W rated, and each 4Ohm at least 12.5W? I realise there are caveats there too.
Cheers,
Adam
If it’s not the valve itself it will be something like a bad connection in the cathode path to ground for the first valve stage. Most valve amps have the first gain stage directly connected to the input jack via a resistor, with no capacitor to decouple any DC voltage - even a tiny leak will make switches pop and pots scratchy. You can check for certain whether it’s this if you have a buffered pedal like a Boss - put that last before the amp and the problems (apart from poor gain in the amp) should stop.
https://i.imgur.com/eaUZRLt.jpg
https://i.imgur.com/KzOAAwu.jpg
If it's not a valve issue I suspect something in the ground connections for V1.
I think the most likely culprit is a solder joint or a broken core in the ribbon cable to V1, by the way - this is quite a common problem with all this series of amps - the problem is that to get at it, you need to take the boards out again which further increases the risk of breaking the connections... it's really not a brilliant design.
Do you have a voltage meter? You can measure the voltages on the pins of V1 and see if there's anything odd. The pin numbers go anticlockwise from the gap so the ones you need to check are all on the side of the socket nearest the end of the board. Pin 6 should have a high DC voltage on it, around 150V I think. Pin 7 is the grid connection to the jack and should be - but won't be now - 0V, and pin 8 is the cathode which should be about 1.3V (all to chassis ground).
