My son bought a second-hand epi sg400 on facebook.
Really nice guitar for the £100 he paid for it but I found the action at the 1st fret very high.
He's changing the strings for the first time and found the nut is not glued in place. Looking at it, it's brand new so guessing someone bought a pre-cut nut and left it as it. The string slots seem fine.
I'm planning on gluing it in at least. Should I use wood glue or super glue (or something else?)
Is it worth marking a 1 mill line around the bottom and sanding it off so that the slots stay the same but overall lower the action a bit or should I stay clear? Never really done any guitar maintenance before, always go to a tech.
That's how I usually do it when I fit a new nut. Just take your time, and take a little off at a time, checking the height as you go. I also round off any edges slightly too while I'm at it, just to make the nut more comfortable. I also run some folded extra fine wet and dry paper in the slots to wear away any sharp edges that may bind the strings. Works for me, and always had good results, though obviously not the most professional method to use.
Oh yes, and fix with a touch of superglue as sweepy says.
