I have a 6-way one on a bass.
It has an EMG SA in the neck and one on the bridge and an SAX in the middle position.
on the SAX pick up I have the EXG Expander pot with makes the guitar sound really glassy, almost acoustic, very bright but with a lot of low end too. SPC boost to the both the bridge and middle pickup which add tons of middle making it sound like a humbucker.
The only thing is that these expanders are wired only to work on a variable pot, which is a nightmare if you need to flick that sound in instantly which I do in a live situation. I can't be messing around rolling a pot up and down , it just takes too long even though it's only a fraction of a second, it doesn't feel right under the fingers in the heat of battle at a show.
The main switch is a standard 3 way Strat toggle.
2 micro switches to bring the expanders in and out, a 3rd switch to bring in the neck pickup
It may require some thought as to how to wire these up...
