Is this headstock repair dodgy?
BidleyBidley Frets: 2928
Looking at buying this guitar, and the seller has been up front about it having had a headstock repair. Although I don't know how concerned about it I should be! Pics...
  • ICBMICBM Frets: 72411
    Probably. It almost certainly hasn’t been done by a professional, anyway...
    It has at least been clamped pretty tightly by the look of it, but the question is what glue has been used - if it’s the wrong type (eg PVA) then not only will it probably come apart again, it will be almost impossible to clean the wood up well enough to use the right type.
    If you’re thinking of buying the guitar, you need to take into account the possible cost of a full professional splint or scarf joint re-repair, plus refinish - then double that, and take it off the final value of the repaired guitar, if it’s to be a safe purchase.
  • steersteer Frets: 1189
    Any repair like this should reduce the price hugely, so unless you are getting a great price, walk away or negotiate hard.
  • guitars4youguitars4you Frets: 14290
    totally endorse that
    Very hard to hide any repair work to a potential buyer with a good eye - But it can be repaired by a professional tech that will make it secure - But any finish touch up will always add extra cost and generally still leave some signs of such work carried out
    ref that pic - I've seen worse, but I'd expect far better
  • proggyproggy Frets: 5835
    Who repaired it?  .....David Blunkett
  • JezWyndJezWynd Frets: 6080
    How noble of him.
  • BidleyBidley Frets: 2928
    I think I'll give it a miss then!
    Shame, it was a great price for a Super Swede (I think I can tell why).
  • HarrySevenHarrySeven Frets: 8031
    From my perspective (which is usually fairly skewed, I admit...), I would totally endorse @ICBM and @guitars4you, other than to add - if it's uber-cheap, go for it (but I suspect it isn't?)
    Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
