WTB: Callaham ) or other high end) trem block to fit Classic Player Strat trem
Anything about pls?
  • dallcorpdallcorp Frets: 139
    Pm sent
  • Still looking
  • stuagustuagu Frets: 334
    Iv got an Eric Johnson fender trem block... but iv no idea if it’ll fit a classic player TRem?
    Any chance of some dimensions / measurements at all pls?
  • CasperCasterCasperCaster Frets: 762
    The Callaham website suggests that the Made in Mexico Classic Player model uses the same block as the Mexican Standard Strat (so 52.5mm string spacing, with the same location for the mounting screws and arm). It should be possible to confirm this, assuming your guitar currently has the original trem, since the existing block should be marked 'PW29' on the base.
    http://www.callahamguitars.com/tech_compatibility_strat.htm
  • CorvusCorvus Frets: 2926
    Kev Hurley block & arm cost me £27.50 delivered if that's any use, he can make any size and various metals etc. I've had three off him now, all good. He's at kevinh66 at hotmail.co.uk
    Apologies bud... forgot all about this... il go measure shortly.
    What do you need ?
    What do you need ?
    Thanks man.
    i guess string spacing and dimensions of the block and the mounting screw holes? Pics would also be nice
  • ADPADP Frets: 184
    The Eric Johnson block definitely won’t fit. You need the narrower string spacing as mentioned by @CasperCaster above. I’ve bought blocks from both Callaham and Kev Hurley (see @Corvus’s post above), and they are very similar in quality. The only real difference is the price.
    I suspected this might be the case so have dropped Callaham a line on their replacement block for Classic Players
  • adampeteradampeter Frets: 775
    This ^
    Cannot be beaten for quality and price
  • ADPADP Frets: 184
    Here’s some information about the block you need from the UK distributor. Unless you’re set on the Callaham name, I’d contact Kev Hurley. It’s £50 more for the Callaham, and to my mind, there’s no difference in sound, function or quality.
  • FelineGuitarsFelineGuitars Frets: 11598
    Our Fatcat guitar hardware blocks are cold rolled steel but at £47 for the block may fall into the Callaham territory.
    Thanx for the info.
  • Our Fatcat guitar hardware blocks are cold rolled steel but at £47 for the block may fall into the Callaham territory.
    Would I need a replacement trem arm?
    would the block be a direct replacement?
    If, as I mentioned above, your current block is the 'PW29' block then it will be drilled for an M5 metric trem arm.
    Many replacement blocks are drilled for Imperial arms, that being 3/16" diameter with a 10/32 thread (what you'll find on a vintage Fender Strat).
    When Kev Hurley was on eBay his default was for an M5 thread, but mine are all Imperial diameter 3/16" and 10/32 thread as that's what I asked him for. I believe Wudtone use metric M5. Callaham (being American) use Imperial.
