Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Avoid the ones with a bottle at the bottom, as they will splatter paint everywhere.
https://www.graphicair.co.uk/paasche-talon-tg-3f-review/
Packaging issue aside (which may have been fixed by now), I like the big nozzle. The cheapie airbrushes tend to have tiny little nozzles that would be easy to lose. I started with this set from Bartsharp, mainly for the compressor, and went for the package deal with the two cheapie brushes...
https://bartsharpairbrush.co.uk/product/bartsharp-airbrush-compressor-tc90t-with-130-airbrush-133-airbrush/
A decent compressor is a good idea - the tank means a much reduced duty cycle (no tank means it always runs when you spray) and doesn't pulse, and twin cylinder means it does less work overall when it refills the tank (adds up to much longer working life). I went with the kit so that I could make beginner mistakes with the cheapie brushes.
Overall, I found the brushes okay apart from paint sometimes building up at the nozzle if I paused a bit between sprays, resulting in a bit of spatter at the next button press. The issue is that the nozzle protector bit is quite small and hard to get into to clean off excess, and unscrewing and refitting is a bit of a pain. With the protector off, access to the nozzle and needle tip for cleaning is fine, albeit with some risk to the needle if one is careless. Actual coverage seemed pretty good to me, but I don't use the gear all that much, and I don't do any detail work (I got it for painting small parts rather than things like painting camo patterns on models). In the end, I splashed out on a Harder & Steenbeck jobbie, which is lovely to use and has a nice big nozzle (but doesn't need a tool to fit/remove it). The H&S has seals that are solvent proof - cheapies can have o-rings that might not survive painting with the likes of enamel paints.
I used a 0.3mm nozzle on the cheapie with the gravity cup, and a 0.5mm on the one with the siphon jar, and the H&S has a 0.4mm nozzle. I'd say the H&S still has a narrower spray pattern than the 0.3mm in the cheapie. The cheapie gravity fed one hasn't been used since I got the H&S, but the siphon one is used for larger areas (the little jars hold about 22ml of paint - lots of painting time).
Some suggestions / recommendations...
Nomad
Covering the nozzle (to block the paint/air mix from passing through) varies depending on the tip arrangement of the particular airbrush. On my cheapies, the nozzle protector is a cylinder with no gaps, so I just press a finger tip against it. On the H&S, there are gaps, but I have a little plastic cap thing that fits around the outside and can be held on while spraying, and that seals enough to get the back-flush.
Regarding siphon brushes, note that there are two types - simple ones where the airflow passes over a small venturi that leads down into the jar, which basically has no needle and very little control, and the type where there is still a needle and nozzle with a chamber which has the same sort of control as a gravity type. Mine is the latter, and the jar assembly screws onto the side. That still needs the proper cleaning procedure to get the chamber cleaned out. I'd imagine the basic venturi type is easier, but I've never used one.
Nomad
Compressor with tank is a must.
Iwata Eclipse HP-CS - it seems to be a favourite of many modellers and has very, very good reviews.
