Recording DI for reamping later, Can I split the guitar like this?
Want to give reamping a try so I was going to use the 'bypass out' on a Planet Waves CT-04 tuner to feed the 'instrument' input on an audio interface while sending the CT-04's 'output' to the effects chain and amp. I'll be using guitars with passive pups. I'll also be tracking the amp with mics at the same time. Is this going to work?
  • Danny1969Danny1969 Frets: 10410
    If the bypass output of the tuner is buffered it will work fine .... if it's not then the input impedance of the interface will be a bit low for passive pickups unbuffered and might suck the tone a bit
  • Nah, the 'bypass' on the tuner is a hard bypass..... so it seems to be a no-go. I was hoping that the hard bypass wouldn't matter because it was going into an instrument-level micpre on the audio interface.
