What are my chances of cutting a pickguard for a humbucker....
....using basic hand tools and a file?
It's a single coil opening, I have a really good template in a metal humbucker mount.
I anticipate drilling holes in the corners and cutting between using a mini hacksaw blade, then filing to finish.
Am I deluded. Is there a better method?
  • the_jaffathe_jaffa Frets: 1801
    That will work. At least with filing you can just sneak up on the line you need. Take your time and keep checking the fit.
  • I did it and it's not too hard. Work slowly and it'll be fine.
  • FuengiFuengi Frets: 2850
    What gauge of file would you use?
  • Winny_PoohWinny_Pooh Frets: 7794
    edited April 2020
    It works fine, just takes ages. Use a flat file to get near the line you marked. Then you will need needle files for the corners and sand paper on a small block to tidy it up.
    To save time on the flat edges you can use a very sharp stiff knife to "scrape" away carefully.
  • FunkfingersFunkfingers Frets: 14553
    It works fine, just takes ages. Use a flat file to get near the line you marked. Then you will need needle files for the corners and sand paper on a small block to tidy it up. To save time on the flat edges, you can use a very sharp stiff knife to "scrape" away carefully.
    Been there. Done that. (Last time was the Höhner JT60 with three P90s before I traded it back to H7. Horrid, brittle plastic.) I will add that the latter stages are better performed with a round file. This more closely replicates the edge left by a rotary cutting tool.
  • I used sandpaper wrapped around a flat file for a softer approach towards the end.
  • saltyseadogsaltyseadog Frets: 17
    It is certainly doable. I made humbucking  pickup surrounds and a scratch plate from mahogany for my ES335 a few years back. A bit of advice, drill all holes out and countersink before cutting out to shape as it will likely save you problems later on.
    I did it with a drill, a couple of decent files and some sandpaper. It's not bad, but not perfect.
    When the Tele body arrives I'll post some pics.
