If it's steel I would probably go with 12s - with the short scale they will feel much lighter. You could go as high as 13s but the nut grooves may not be cut wide enough for them if it came with 12s originally.
If it's nylon, either the ones GTC suggested, or just use a normal set of Hard Tension or even Extra Hard Tension, for the same reason - Normal tension will feel like elastic bands and not play in tune properly.
Red meat and functional mushrooms.
Persistent and inconsistent guitar player.
A lefty, hence a fog of permanent frustration
Not enough guitars, pedals, and cricket bats.
USA Deluxe Strat - Martyn Booth Special - Epi LP Custom
FX Plex - Cornell Romany
This is a guitar I bought for my boys to see if they got into it. Forgot I had it!
Am looking forward to getting it restrung.
