HINT 1) You might be able to achieve the improvement that you seek by just replacing the original MIJ bridge saddles with Mustang ones of the correct fingerboard radius.
HINT 2) Rubber tubing down the "thimbles" reduces bridge rocking movement sufficiently to maintain intonation without impeding the vibrato action.
and very responsive. You can argue about the merits of it vs a regular offset trem modified or stock and whether it is “worth it”, but in terms of it doing what you want it to do and you not having to fuss with it, it is real set and forget
