Hi all
When I next restring my guitar I intend to put a cover back on a pickup I removed for some reason many years ago (reasons unknown).
I've just noticed that the pickup seems to be in the wrong way round - the pickup has the adjustable screws nearest to the stopbar end, as does the bridge pickup. From looking at similar guitars online the neck pickup seems to have the screws nearer to the neck.
Is there a right/ wrong way or did I managed to put the pickup back in the wrong way all those years ago? And, if so, does it matter?
Martin
I can assure you there will have been no thought behind why I did it at the time - I think I just wanted to see what the pickups looked like under the cover!
Bandcamp
By the way, is Peter Green still playing?
In the real world, no two coils are exactly alike. Many of my favourite humbuckers have one coil intentionally overwound compared to the other. Where this has been done, rotating the pickup through one hundred and eighty degrees will produce a minimal change in the sound. Then, again, so would changing to a mounting surround with a different pitch angle built into it.
Guitar sounds are subjective.
If you like the sound of your guitar with the neck position pickup in its present orientation, leave it like that.
This will almost certainly change the sound of your pickup. Depending on the metal type, the cover will direct more of the magnetism towards the strings. Expect a slight roll off of extreme high frequency treble content. The manner and the firmness with which the cover is fastened can also make a difference. There are various techniques for minimising microphonic squeal.
CAPTAIN'S LOG SUPPLEMENTAL:
1) On some circuits involving humbuckers with twelve identical polepieces, 4-con + shield output cable and a glued-on bar magnet, the pickup orientation could be critical to maintaining hum-cancellation for some selector switch coil permutations.
2) With the DiMarzio Bluesbucker, pickup orientation determines the position of the stronger coil. This will affect both the full and split mode sounds.
Thanks to everyone for their responses. I will see what I feel like when I get down to restringing. As I recall, the cover was attached with some double-sided tape (small piece) and soldered.
The sound isn't really my concern as I tend to use the bridge pickup. I now prefer the look of the covers and I am trying to reverse some of my odd choices from many years ago (including losing two of the knobs...)
Magnetically and electrically reversing the pickup might not give *exactly* the same sound - because it does depend to a tiny extent on the magnetic interaction between the two pickups - but it will be extremely close, and without knowing which it is you will not be able to tell from the sound of the guitar. There is no special 'response to pitch' or 'sweeter and more musical' sound from reversing the pickup magnetically rather than electrically. That's just mojo-waffle...
It also ignores the fact that Green's Les Paul has an unusually distinctive sound even when played on the completely unaltered bridge pickup, which you can hear when Gary Moore and Kirk Hammett play it too - the 'magic tone' is in the wood.
There's another story about a bad pickup repair at Macaris where one of the coils or rewired with what would have been 60s Fender style wire on one of the coils, so this being done badly or a magnet flip at that point would seem a likely candidate
Yet another story says the pickup was installed reversed in an attempt to cure the out of phase-y-ness - either by Peter or by Macaris
It's still a great sounding guitar and given the value, I'm totally impressed that Kirk Hammett still gigs it
Also agree with @ICBM that you can hear it still sounding very distinctive on just the bridge pup - none of which is explained by the above
Sadly Peter has had a hard paper round and I don't think his memory is great
If you want to know for sure what the deal is with the guitar, ask Charlie Chandler - he did the headstock repair when it was broken in Gary Moore's car accident
