My teenage son was keen to build a guitar during the lockdown, so ordered a Harley Benton Ukulele, and a "T Style" kit. I felt I should join in so bought a "Single Cut" kit. Overall, I'm quite impressed for the money. It has a couple of issues though:
- The pickguard is scratched up, but T Cut should fix that.
- The top is pretty good, and could be OK for a sunburst finish, but there are some rough spots between the body edge, and the binding, so will need to be opaque finish to hide the filler here.
- The worst issue, is that the truss rod cover screw holes are in the wrong place, so will need filling, and redrilling.
I had initially intended to return it for the flaws above, but overall it's a light, resonant body, good neck, and Thomann offered a £10 discount if I didn't return it. I suspected that a replacement may be worse, so accepted the discount.
I'm gonna start working on it these evening, but not sure how to deal with painting, and the binding. Do I just mask it off, and build it up with clear coat afterwards?
