I don’t have a diagram but it should be easy to work out - just connect both switch rotors to the volume control and the terminals in each position to the pickups you want on.
1. 3 Singles
2. Neck and Bridge
3 No and no!....
Ill probably stick with the 5 way! I’snot compulsory to use the bridge and middle together, I just wondered if it were possible...
A remarkable number of Strat players never use the middle pickup, and quite a lot never use the bridge even with a tone control.
