Greetings folks,
Whilst I feel i've had superb results with the excellent nitro cans from
@SteveRobinson from Manchester guitar tech, id like to branch out into a 'proper' spray setup.
So. HVLP or 'standard' spraygun?
I plan on the full range of finishes - clear coat over bare/stained wood, bursts, solid colour, metallic, flake, flip-flop. Im also keen on finishing a guitar with the Al-Clad Chrome to attempt a Satriani Chromeboy finish.
If HVLP, then it becomes easier as an all-in-one package, but limited if i want to add other guns.
If normal spraygun, then which brand/model of gun, which compressor?
Many thanks, as always, for advice given.
Adam
I think a respected “normal” cup gun is a Devilbiss gti pro lite. I have a “Morrells Signature 1” which is okay, but plan to upgrade. However, I’ve noticed that some guitar sprayers use the smaller Iwata ones which may be more specialised for guitar finishing? If you want to get into metal spraying then you might need a bigger tip size to accommodate the gloopier material coming though.
As far as the metal spraying, its not thick at all - its a low viscosity lacquer produced primarily for achieving a metal look on model kits.
https://www.alclad2-online.co.uk/product/alclad-ii-chrome-for-plastic-alc107/
Any thoughts on suitable compressors?
Cheers
Adam
I had an A.S.I. turbine & gun (can't remember the model) and got some great finishes with it... the noise doesn't half grate on you though! You can get great finishes from them.... but maybe for a little bit more investment having the compressor and cup gun then gives you the option for other air tools like a pin gun etc which might be useful for other DIY things? Just a thought.
I have a Nu-Air belt driven compressor which has been good, but to some degree they all seem the same to me lol! I think belt driven ones are considered more robust (other than blowing 3 grand + on a screw compressor!)
I don't really know enough to give good advice though .... I'd recommend giving somewhere like SprayGunsDirect a call as they can sell you the whole kit, compressor too and would be able to give more tailored advice.
Thanks again,
Ada
It's really good because it's super easy to clean down after use and you can use the gun upside down and every which way round.... the only downside is that it's annoying to refill (not an issue with guitar spraying) and you can't spray out every drop of lacquer so it's a tiny bit wasteful with 2pk paints... but the pros might still outweigh the cons. Worth a quick look anyway.
