Drilled the wrong tuner hole!
Hello friends
So working on a tele neck and got some gotoh locking heads and the brushing wouldn't fit, did some googling and saw that 10mm is a standard on modern heads?
Held a 10mm bit up to the blushing and looked like a match, but it's super loose now, checked the website for the heads and its 8mm, doh!
Lesson learned and o ly redrilled one hole, anything to be done about it?
  • vizviz Frets: 10719
    Glue and cross-grain dowel and redrill I guess
  • phil_bphil_b Frets: 2010
    edited April 2020
    Hello friends
    Only thing I can thing of is to glue in a maple plug into the hole then re drill
    or wrap tape arount the head to thicken it up so it fits the hole
  • ICBMICBM Frets: 72566
    Drill them all and fit a set of 10mm heads. You wanted those anyway, didn't you?
    That is actually not a bad idea
  • FunkfingersFunkfingers Frets: 14563
    If your locking Gotoh 'heads are the Kluson lookalike Magnum type, it ought to be possible to use adapter bushings.
  • all good ideas, i went for the quick and easy tape option and git it nice and snug, not quite as tight as the others but its my first build and its good enough for me
    only just started doing this so there is a lot to learn!
  • Winny_PoohWinny_Pooh Frets: 7795
    Buy conversion bushings
