Often, there is a sequence in which soldering work is easiest to perform. On a three-way lever selector switch, attach the jumper connector wire(s) before the “hot” conductors from the pickups.
If your humbucker output cables have braided wire screening, prevent this from accidentally coming into contact with any metal parts in the signal path. If necessary, wrap insulation tape over the braid.
