The stain won't take if there's any oil left on or near the surface.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
As @Sarge says, make sure you are down to clean wood. Easiest way to check is to wipe it down with a damp (not wet) cloth. If the neck darkens evenly with the dampness, it should be OK. If there are light patches dotted about, then those areas are likely to still have some oil ingrained in the wood surface.
