Hi,
In the past year or so I’ve started to have tuning stability issues with my Gibson firebird. I’ve not been in a band or doing recording, just doing various stamina and speed building exercises which don’t necessarily need to be perfectly in tune, so I hadn’t been paying much attention to the tuning so long as it was near enough.
However after a jam with other musicians a few months ago it was really apparent how badly it was slipping. More recently i changed down a gauge from 11s to 10s and got one of the steinberg tuners (low e) fixed, did a rudimentary setup and made sure i stretched the strings until there was (apparently) no more play, but there are still issues.
The worst offender is the low e, which goes way out, usually sharp but there’s no obvious pattern. The higher strings are more stable, but I used to be able to play a whole set without much movement, and now it seems like it’s never actually in tune across all the strings.
Where do i start with troubleshooting this? I won’t be going to a tech anytime soon!
An easy way to check is to first tune the guitar. Pluck the E or whichever string is giving the problem, press the string down on the far side of the nut , release it. Then check the tuning again, if it's sharp, the string is sticking in the nut slot. It might need some filing or possibly just lubricant.
Fingers crossed and thanks for the help.
I cleaned out the nut with a soft toothbrush, used some nut sauce and the problems have almost completely gone.
Almost.
Low E still moves around more than I like. When I play my tele it is rock solid. It just doesn't move no matter how much I play.
What is the next thing to check for to work out where the movement is coming from?
A Firebird can only have such a steep neck angle - given that it's a through neck - by design, so I wonder if yours has the same problem... if so you can probably reduce it by raising the tailpiece, but you might have to fit a roller bridge or some other way of reducing friction there.
https://www.dropbox.com/s/9wkpte1y4avt2uz/77245771-6988-4F6A-9A7C-F5DB4A030324.jpeg?dl=0
(edit: I keep trying to post the link to the top down shot but dropbox keeps linking to that same pic - if you need the other angle it's in the same 'public' folder as the the 'bottom up' shot)
I must confess to not knowing the correct angle for this kind of bridge - is this just too steep? If so, do I need to loosen the strings before raising the tailpiece?
I would raise the tailpiece a bit further and see if it makes any difference - not under full string tension, and if the studs won't turn use a coin not a screwdriver, that's what they're designed for!
Obviously, being the idiot that i am i used the enormous screwdriver that was to hand (no coins in sight) and slipped, denting the finish. It’s fairly roadworn as it is but annoying nevertheless!
Thanks for your help guys, it’s great to have this resource particularly when I don’t have recourse to my kneejerk ‘take it to a tech’. About time i finally learned how to do this myself after over 20 years playing...
It looks worse than it is because the pickup is leaning the wrong way in its mounting ring.
Perpendicular to the body surface gives the most stable posts, provided the angle on both sides is reasonably similar.
When I hit the E it doesn't have a consistent note. It may start in tune, but it then pitches up at bit. When I hit it again it does the same thing - it is the correct pitch for an instant then shifts up.
Any ideas? Busted machine head?
