FS: Firebird copy pickguard (pickups, neck, machineheads etc sold)
These are some parts from a bolt-on Firebird copy, suitable for a project - from what I understand it was a Westfield, and the rest of it met a nasty end...
The neck is maple, appears in pretty decent condition although the headstock face has been badly sanded and the fret ends could do with some attention. The headstock is 'non-reverse'. 24-3/4" scale so will *not* fit on a Fender-type body without some adjustment to the bridge position. £30
The pickups measure 8.4K each and seem well-made - they're quite heavy and feel chunky. £20 each
The machineheads are a complete set and do have the threaded collars and washers (not in the pic) - £20 the set
Pickguard - reverse style - £10
All including postage.
I also have the tune-o-matic bridge and stopbar tailpiece if you need them, but I can just as easily use them myself so not including them just now.Neck, machineheads and pickups sold. Pickguard still available.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
I also found the original nut, if it helps anyone - it’s a fairly decent hard plastic. Definitely from the neck since the mark from the miniscule amount of glue used is still visible .
Indeed they have.
Pickups and pickguard still available.
Just the pickguard left now.
