wondering if i can get some help with my wiring
hello everyone!
got some micro burns trisonic and excitedly got them all wired up today, but i really need to stop following diagrams and learn what im doing becasue troubleshooting is impossible
so the burns come with 3 wires, 2 green and a red/black/white, different for each pickup. I assumed the grounds were the greens so soldered them together
i followed this diagram, with the switch for a 7 way, becasue i dont like pull up pots, i used one half of a DPDT rather than an SPDT
https://www.sixstringsupplies.co.uk/gilmour-strat-wiring-mod
i also wanted to test out a bit of phasing, so i added a switch with this (next link) to my middle pickup, so i can switch it in and out and get a bit more range tonally
https://www.warmanguitars.co.uk/2019/03/04/how-to-wire-a-phase-reversal-switch-into-your-guitar-pickups/
now, the wiring went well, but I have no idea what i have done and why its coming out the way it is.
This is what happens on my 5 switches (neck switch is the 7 way david gilmour trick)
1 just neck, neck switch turns it off
2 all three, neck switch turns all off, phase switch makes them all a bit crackly
3 neck and bridge, neck switch turns both off
4 neck and bridge, neck switch does nothing
5 bridge, neck switch turns neck on/off
phase switch does nothing for any of the other settings because the middle pickup isnt coming through.
also i notice when the neck switch is turned off there is a hum (more prominent in position 3) but its not a normal hum, its a slow rhythmic on and off , on for a secong, off for a second
i really hope someone can help put me on the path to knowing what im soldering where, and why!
thanks in advance for anyone who can spare me some time
J
  • FunkfingersFunkfingers Frets: 14571
    edited May 2020
    Duplicate Discussion.
