I found the Maxon delays, AD900, 999 very dark. They’re beautiful delays, very hi-fi sounding for analog but not really suitable for rhythmic bass repeats.
The PT2399 chip is a good call, I had a VFE Delay a couple of years ago which used that chip and it was an excellent analog voiced digital delay.
Am I right in thinking that the eq pedal in the loop only affects the repeats and not the initiating note? It sounds that way from the video but not certain. If so, it sounds an ideal solution, if a bit complicated.
Fwiw I once briefly owned the AD999-Pro, which has little switches for tapping the signal after different BBD chips. It was so dark that as a source of rhythmic delays, it was useless. I've also had the AD9-Pro, and that was very dark indeed - you could whack the delay level up full and it still wouldn't stand out next to the dry signal!
i could not escape the murkiness and low fi sound with the MXR Carbon Copy deluxe I tried. I had been in same boat.
-Seymor Duncan Vapour Trail
-Way Huge Echo Puss
-Strymon El Capistan or Brigadier
I went with the Seymour Duncan to start with. That's an excellent analog delay, it stands out well but also sits nicely if you know what I mean. The repeats are warm but but quite clear to start with. The modulation works well and it is easy to add a subtle amount, unlike the 616.
I've since bought an El Capistan and I'm finding a lot of good sounds in there. I wouldn't say that I've been able to get it to sit so well yet though, but I haven't tried it in a band context yet. Different beast entirely. But it is very tweakable and can be set to sound a bit like an analog delay, although that does miss most of the best of what the El Cap offers.
Genuinely, I would look in to the Vapour Trail. It's not boutique cool but it is solid. (Sorry I might have missed some details as I skimmed a lot of the thread this time around).
So far, very impressed: it's a superb sounding, highly controllable, bucket brigade-style delay. I think it's going to replace the El Cap on my board as I prefer the sound - there's not much in it, but my preference is the Brig, particularly with modulation on.
As well as the visible "bucket loss" control, it has a hidden filter/tone control that can be set to darken or brighten the repeats, so it can be very bright without noise (to answer the OP's original question). In fact, this is a more useful control to my mind than the bucket loss control, which may be realistic (or not) but would be more of a set and forget for me. For some reason hardly any the online demos I've seen (e.g. comparing with things like EHX Memory Man) mention this.
Far more pleasing has been a Lovepedal Echophonic v1. One cropped up on eBay and the tone control tempted me to give it a shot. I can’t find much about it but I’m sure it’s not analog; it’s too quiet and the tone control brightens up the repeats nicely. 700ms max works well for me and it’s easy to operate, something that makes me wary of the Strymon pedals with their ‘keep x depressed to initiate y vibe.
Currently have a long chip DD-3 incoming, I’m hopeful that the combination of the Echophonic and DD-3 will suit my requirements. If not I’ll revisit the Brigadier.
