We’re cracking on with the kitchen and have come across something I wasn’t expecting in the builders opening that was bricked up, probably in the 60s/70s.
There’s a rusting pipe installed like a bit of a supportive lintel even though the arch above is the original supporting structure.
Just trying to get a sense of what it might be before I rip into it. Maybe there was a gas fire at some point that was later even yet again bricked and the lintel was out there at that stage to support the smaller opening?
its just above the plaster in the photo
cheers
What are you intending to do? The arch is perfectly fine supporting the bricks above so you could remove the bricks below if you wanted. If it's a chimney breast that you want to remove you'll need an RSJ to support brickwork above.
I would also say it was taken from the wall on the side and was an iron gas mantle supply pipe in it's first life and was just handy for the job at the time
