Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
If the nut recess is damaged, you can make a tapered Allen key by starting with the next size up and grinding it down - you can then hammer that into the nut if necessary and it will both grip and partly re-shape the damaged recess so you can turn it. You'll need to replace the nut once you've got it out, but that's the easy bit...
For the worn nut, I also reshape a larger size... But remember to replace the Allen key for when you need the proper size again.
Instagram
Updates to follow ASAP...
https://i.imgur.com/hmYDndO.jpg
https://i.imgur.com/V0uNGEN.jpg
https://i.imgur.com/TdDlcSH.jpg
Instagram
The board was a real sod to remove and there’ll be quite a lot of tidying later on.
Nevertheless - onward and upward!
was going to point to CH guitars for a selection of cheaper slotted/radiused/inlayed/bound boards in a few scale lengths, but all seem to be out of stock
https://chguitars.co.uk/product-category/necks/fingerboards/
Instagram
Yeah, I've ordered a replacement truss rod from chguitars, but just spotted that the boards are out of stock...
Just buy it! Don't just think about it!
